VFD for the motor
VFD for the motor
I have some questions about the VFD, does anyone here could help? thanks.
1. Is power factor (input side of VFD) in VFD's name plate? if it is, I just wonder if the motor's PF is different with VFD's PF, which one should be used to calculate P and Q in the VFD's input side?
2. does VFD produce/absorb the Var to/from the system?
thanks again
David
thanks again
David
RE: VFD for the motor
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
