Import dxf from google sketchup into RISA-3D
Has anyone created a model in google sketchup, exported it as dxf and imported that dxf into RISA? I completed the steps but nothing shows up.... Any input would be appreciated. Thanks!
RE: Import dxf from google sketchup into RISA-3D
The most common mistake make with DXF importing is that RISA only imports LINES as members.  The program does not import polylines.  If the lines are defined as poly-lines in the DXF file then they will have to be "exploded" before they can be imported into RISA-3D.
