Normal view when creating sketch
RE: Normal view when creating sketch
The plane rotates to the Normal to orientation automatically when starting new Sketch. Would you like to turn off this option?
Artem Taturevich, CSWP
Software and Design Engineer
AMCBridge LLC
www.amcbridge.com
As far as I know this only occurs for the first sketch in a part.  The option would be nice, though.
Dan
www.eltronresearch.com
Dan's Blog
I'd put in an enhancement request to give an option in System Options > Sketch to "Orient to 2d sketch view on creation On/Off"
If you add that this is supported functionality in Inventor, it usually helps.
I like the fact that in SolidWorks if you're editing a sketch Normal To icon automatically activates the Sketch X-Y view orientation.
You can add a Shortcut Key in Tools > Customize > Keyboard
N = Normal To
Then hit N after activating Insert Sketch.
Michael
I remember this option was earlier there in SW2006 and has been removed after SW2007.
Deepak Gupta
SW2009 SP3.0
SW2007 SP5.0
MathCAD 14.0
I checked in SW2006 but couldn't find the option for keeping normal to...sadeyes
Deepak Gupta
SW2009 SP3.0
SW2007 SP5.0
MathCAD 14.0
You can also create a macro that automatically starts the sketch and sets the view to NormalTo.
