Symbol/Indication for where to apply solder
Is there an industry standard/accepted symbol (like a welding symbol) or something to indicate on a drawing places to apply standard tin/lead solder on thru hole components? Just working on some assembly drawings and wanted to indicate all points where solder must be applied..
RE: Symbol/Indication for where to apply solder
I was reading the notes on welding in Global DRM and it briefly mentioned soldering.
I believe it is covered by the AWS standards, probably 2.4.
http://www.aws.org/w/a/weldinghandbook/9v1.html look in the content of section 8.
It might be covered as a type of brazing, I don't know for sure.  http://www.aws.org/w/a/associations/bsmc/stdspc.html
KENAT,
Have you reminded yourself of FAQ731-376: Eng-Tips.com Forum Policies recently, or taken a look at posting policies: http://eng-tips.com/market.cfm?
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
I saw that table of contents but don't have access to any of those welding standards as we don't do/spec any welding at my facility.
I figured though that it really wasn't talking about the same type of "soldering" as electrical component thru hole soldering so I figured it wouldn't apply.
Any other ideas? I might just pick a symbol and add that to our own internal rules/standards.
You might also look in the IPC standards to see what you can find.
Yes I have already emailed IPC to see if they have a standard that might reference that (no response yet).. Thanks
