what means BLUED AND OILED CARBON STEEL
Asking for paint system, I would like to know what does mean "valves are supplied blued and oiled carbon steel".
usually I can see zinc phosphate or else.
thank you for your help
RE: what means BLUED AND OILED CARBON STEEL
You probably need to remove the entire surface oxide and oil, then perform your painting process. You may or may not need the phosphating.
