H13 steel Heat treatment
Hi friends,
I have a cylinder and a piston made of H13 tool steel.
The working temperature for these parts is above 600C. The piston has to slide in the cylinder on those elevated temperatures.
I would like to know whether it is possible to achieve a microstructure in H13 steel that the parts do not loos their hardness in operating conditions? Or should I change the material?
Since the inner dia of cylinder is 40mm and its lenght is 500mm, it is not possible to coat the inner surface of the part to maintain the hardness and the only solution that remains is heat treatment. Or you have any other suggestion?
RE: H13 steel Heat treatment
rp
htt
