3 phase transformer tap changes
Somebody mentioned that by changing the taps on a three phase transformer, it is possible to have a consumption saving.I do not agree cause, if the voltage goes up, the current will go down equally and supply the same amount of power.Is there an impedance savings or something I am missing?
RE: 3 phase transformer tap changes
Either way... you have posted in the wrong forum :)
Hi, where should i post it then?
