Pump design spreadsheet
Hi guys:
I am looking for a good pump design spreadsheet that can do head cal., efficiency etc, for pump selection. Can anyone can help me for that?
tsli
tsli
RE: Pump design spreadsheet
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
Those should give you a good feel for what is available.
"We don't believe things because they are true, things are true because we believe them."
Is this a spreadsheet you did up? It comes up as an excel spreadsheet when I open it, with no identifying information.
Patricia Lougheed
Too cute.
There is a lot of science that a person could throw at this, but at the end of the day it comes down to comparing pump curves received against the operating range you want to cover.
If asked to be predictive up front, if someone permits me to be scientifically creative, I would start with the assumption that, for centrifugal pumps for example, the characteristic head-capacity curve is a concave downwards parabola of the form:
H = C1 + C2*Q + C3*Q^2
(sometimes I add a fourth term "... + C4*e^Q..." because I have found that equation form is a better fit for most of the curves I have worked with, and it reduces the drop-off and improves continuous rise to shut-off - perhaps coincidentally - near the dead-head range)
I then would arbitrarily pick a "% rise to shut off from BEP", considering how flat a characteristic I want. With that, I can usually get a pretty accurate indication of what C1, C2 and C3 are.
I then would pick an arbitrary pump maximum efficiency at BEP and, again, assume a concave-down parabola with vertex at BEP and Y-intercept at (Q=0, H=0).
Then, when I got the pump curves, I could plot the actual data points from each against the theoretical baseline thus derived and make an assessment as to which comes closest.
Where pump RPM and impeller sizes need to be considered, the affinity laws can easily be applied.
I often take the backwards approach as well: fit equations to actual pump curves and then vary the operating conditions to predict performance. There is some limited curve fitting capability in EXCEL, but I find that there are a few reaaly good - and basically free - Shareware and Freeware utilities that do a much better job. Two that come to mind are the old DOS-platform XYMATH and the somewhat newer CURVE-EXPERT.
The nice thing about the above approach is that once you have built the template the first time you can fiddle with the constants C1, C2, C3, C4 to "shape" the curve you want and then go looking for the closest fit from the vendors, so it's not a "one-time" tool.
SNORGY.
See the last sheet for the info. you are asking...
My apologies. I didn't make the spread sheet full size when I first opened it and so all the different pages didn't show up.
Patricia Lougheed
