Draging geometry in sketch
I'm using SWX 2009 sp3. it started suddenly and I can't find the option in the tools.
when I drag my sketch element itself (ex. line) it tries to produce a copy and gives me an error message after. but if I drag the point it works fine. how do you get back the classical behavior.
thanks,
thanks,
MTM
CSWA Certified
ATC Certified
CAD Blog
http://mtm-cadtutorials.blogspot.com/
Profile
http://www.linkedin.com/in/mtmcad
RE: Draging geometry in sketch
What is the error message?
Do you have another machine to install the Copy Settings from?
Check you don't have a 'sticky' SHIFT key. Easy to check in notepad etc.
Chris
SolidWorks 09, CATIA V5
ctopher's home
SolidWorks Legion
Deepak Gupta
SW2009 SP3.0
SW2007 SP5.0
MTM
CSWA Certified
ATC Certified
CAD Blog
Profile
