Eyelet (Grommet setting tool)
I am trying to source a tool and or drawings for the setting of MS20230 eyelets or grommets in some areas.
Most tooling around will set the commercial type with a straight barrel not the tapered type on the MS.
(AN230 was the old spec)
Size is 0 and it is a plain washer (Al or Brass per spec)
self piercing. Embosed head style.
Any help appreciated.
RE: Eyelet (Grommet setting tool)
Stimpson makes a bench top tool with the tapered anvils. I don't see a tapered hand tool anywhere.
Still trying to find a dwg of tooling. Guess it is like rocking horse poo to get.
Thanks mate
Thanks for your reply.
Kal
