Deselecting one edge of multiple edge blend?
I'm using NX5.0.4.1, and since I've migrated up from NX3, I can no longer deselect just one edge of a previously created blend in which I had selected multiple edges.
For example, I created a blend and selected 5 different edges (none of them tangent to each other or connected to each other, all independent edges of the same solid). Later on, I want to modify the blend by deselecting 1 of the 5 edges, but when I hold down the shift key and select the 1 edge I want to "unblend", it deselects all 5 edges, leaving me with no choice but to reselect the other 4 edges.
In this example it's not that big of a deal, but I sometimes have 10+ edges selected in a single blend, and it becomes a real pain to do this.
Any suggestions?
TIA
Any suggestions?
TIA
RE: Deselecting one edge of multiple edge blend?
Check with your local support if you want more information.
Now that being said, there is one thing to remember, if you had set the Selection Intent to say Tangent Edges and there were no tangent edges when you selected the edges, it will behave, at least at that moment, as if they were selected with the Selection Intent set to 'Single Curve', but the model will remember that it WAS looking for tangent edges, just that it never found any, however, if the model had been changed and perhaps other feature reordered such that during a model update, the system did suddenly find a set of tangent edges containing at least one of the original 'individually' selected curves, this set of tangent edges will now behave as tangent edges when you later attempt to deselect only one of them. This is why it's called 'Selection Intent' since the 'intent' is retained and will come into play if the conditions of the model changes so that they are now able to be fulfilled, even if originally they were unable to recognize a tangent edge condition.
Anyway, under normal circumstances it should work as you expect, but there is at least exception as described above which you may wish to look for.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
This is good to know going forward, but it will still be a problem when I create blends with multiple chains of tangent edges.
Thanks for the input.
WinXP-SP3 / NX5.0.4.1 MP6 / Catia V5r18 / NX I-deas 5.3.0.14
What this says is that perhaps this was problem which has been fixed in a later version of NX 5.0. Now I should have checked NX 5.0.4.1 while I was still in the office earlier today, but now that I'm at home, running an archive version over the net is really sloooooow.
John R. Baker, P.E.
Industry Sector
Cypress, CA
