pressure - Pa vs. Psig vs psia
I have a question and need some help on this - I have a vessel and is rises to 25 psig - when I find the vapor pressures for the particular chemical - do I add 14.7 first then multiply by 6894 to get Pa so I can read my correspnding temperature..... I am confused!!!!!!!!!
RE: pressure - Pa vs. Psig vs psia
25 psig = 172368.932 Pa(gauge) = 273721.865 Pa (absolute)
25 psig = 39.7 psia = 273721.865 Pa (absolute)
To make my point, you can either convert psig to Pa (g)(multiply by 6894.76) then convert Pa(g) to Pa (a) (by adding 101352.9) -or- you can convert psig to psia (by adding 14.7) then convert psia to Pa (a) (by multiplying by 6894.76). Both give the same result.
(Note: 14.7*6894.76 = 101352.93)
Good Luck
jproj
P.S. Keep those units straight.
