hirth coupling
hirth coupling
Hi
I'm looking for any info on the design of hirth teeth, primarily why the need for such a high surface finish and tolerance. I'm guessing the high tolerance is an alignment thing as probably these coupling are used for high speed applications.
Anything would be useful.
I've already viewed this thread:
http://www .eng-tips. com/viewth read.cfm?q id=88618&a mp;page=10
I would be quite interested in a copy of arnoldh design notes, if they are still around.
thanks
allan
http://www
thanks
allan
RE: hirth coupling
1) Hirth couplings are used for angular positioning. Machine tools use them on tool turrets. If you want to position the tool accurately then your teeth need to be accurate.
2) Load sharing between the teeth only works if the teeth are accurately spaced and sized.
RE: hirth coupling
Here is a fair bit of info from about four years ago.
http://www
RE: hirth coupling
Oops, didn't notice that, sorry!!
RE: hirth coupling
Would you have any references, best practice guidelines for tolerances?
thanks
allan
RE: hirth coupling
