Stainless Steel pipe flanges
Hello Everyone,
I have a need to connect a 24-inch 316 Stainless steel pipeline to a 28-inch SDR17 HDPE pipeline. While the IDs are pretty close the ODs are not obviously. Is there a larger flange than can be welded to the stainless side so that the flange holes/bolts will line up, or should a reducer be used?
RE: Stainless Steel pipe flanges
jt
