Oscillation when modelling Sand Filter
I am modeling a site and breaking it up into drainage area per BMP. I have a drainage area a little over an acre and am trying to model a sand filter treating this runoff. I have the sand filter modeled as 2 ponds. The first pond is the sedimentation chamber to allow settlement of large solids, then overflows into the second pond with the sand media allowing exfiltration. This sand filter is designed to allow storage to reduce peak flow. My problem is, I keep getting really bad oscillations with dynamic routing. Even after reducing dt all the way and increasing finer routing all the way I still get the oscillations. I get warning 87 and 80. The 80 says that pond2 exceeded pond1 by .01'. Is there any way to smooth this out? Any better ways to model a sand filter with sedimentation chamber and storage? Should I just not model a sand filter in hydrocad?
RE: Oscillation when modelling Sand Filter
If you have questions about a specific file please send it to HydroCAD support.
Peter Smart
HydroCAD Software
www.hydrocad.net
You can send the file to support at hydrocad.net
Peter Smart
HydroCAD Software
www.hydrocad.net
When setting up the storage defintion for the side with the sand filter, be sure to select the option to "allow exfiltration". But deselect this option in the storage definition for the closed side of the trench.
Peter Smart
HydroCAD Software
www.hydrocad.net
The image you posted is what is commonly called the "Delaware Sand Filter". I have used this device on a number of occasions. As far as modeling the hydraulics of this, I would like to offer a few notions.
1. The starting elevation in the sedimentation chamber is at the weir (there is no routing storage available below the weir as it is already full of water. There is negligable storage above the weir.)
2. The flow through the sand chamber and outlets is always more restrictive than the flow throught the weirs connecting the chambers.
When one tries to model this in detail, it creates a backwater condition between the two chambers which is causing the oscillations. Software that utilizes true full dynamic equations in routing may handle this without oscillations but that is serious modeling overkill and would unlikely yield significantly better results.
Because of this, my approach has been to ignore the sedimentation chamber and just model the sand chamber.
In the attached example:
The storage is defined for each precast chamber with a multiplier for the number of chambers. The first 0.5' of depth is gravel with a void ratio of 40%. Then next 1.0' depth is sand with a void ratio of 40%. Above that is open storage (one could use the volume of both chambers at this point).
The discharge in this example is perforated 6" pipe (0.5" holes) runing into an 8" collector/discharge pipe.
