Assembly Section Views and Fasteners
Hey guys,
Can anyone tell me what ASME Y14.3M has to say about doing assembly section views containing fasteners like bolts, screws, nuts, washers, etc.???
We are in a debate at my work about what objects you don't section in a section view. All I have here are subsets of the ASME standard (GD&T, Revisioning, etc.) and some school text books. It looks like you don't section some items, but I'm not sure exactly what. Is there's a simple rule to this?
Thanks SO MUCH in advance for some help on this -
Jack
Jack
Jack Lapham
Design Systems Engineer (E20)
Leupold & Stevens, Inc.
www.leupold.com
RE: Assembly Section Views and Fasteners
Does say at the end of 3.1.1 "Section lining may be omitted where drawing clarity is not affected".
I've typically seen fasteners and similar not sectioned, but for an item like a washer I'm not sure of the typical convention. I suppose which ever gives more 'clarity'.
KENAT,
Have you reminded yourself of FAQ731-376: Eng-Tips.com Forum Policies recently, or taken a look at posting policies: http://eng-tips.com/market.cfm?
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
4.3.1 Sectioning Assembled Items. Where the cutting plane lies along the longitudinal axis of items such as shafts, bolts, nuts, rods, rivets, keys, pins, screws, ball or roller bearings, gear teeth, spokes, and the like, these parts are not sectioned except where internal construction must be shown.
KENAT,
That was exactly the verbage I was looking for. I've found similar wording in documents that reference ASME and DOD drafting standards.
For example:
Shafts, bolts, nuts, rods, rivets, keys, pins and similar solid parts, the axes of which lie in the cutting-plane, should not be sectioned.
Engineering Drawing and Design, 4th ed., 1991, pg.161
and...
Shafts, nuts, bolts, rods, rivets, keys, pins and similar pats, whose axes lie in the cutting plane, are not cross-sectioned.
Drawing Requirements Manual (based on DOD-STD-100), 6th ed., 1986, pg.3-23
Anyway... thanks you guys... that was exactly what I was looking for.
Jack
Jack Lapham
www.leupold.com
