NX5 Assemblies: Tangent to swept feature
Don't know what the best course of action would be here. I created a helix, then swept a rectangle along the guide using the "swept" feature to create the groove you see. I have an outer sleeve with a pin protruding and I want to make the guide tangent to the pin. I already have an "align" constraint between the outer and inner sleeves. And I'm getting an error when I try to apply the "tangent" constraint. I tried applying the "tangent" to the face of the pin and to the edge but both give me an error. Ultimately, I would like to be able to constrain the two so that the inner sleeve is concentric to the outer and when I reposition the inner sleeve in or out, it rotates according to the pitch I specified.
Al
Al
RE: NX5 Assemblies: Tangent to swept feature
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
I was using similar methods for animations and finding that the over centre rotation of any cam or geared mechanism using constraints was giving me headaches by swapping sides.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
