Mission Segment Weight Fractions
I'm currently reading Aircraft Design:A Conceptual Approach by Raymer. On page 31 there is an example of sizing calculations performed on an anti-submarine aircraft:
Mission Segment Weight Fractions:
1) Warmup and takeoff W1/W0 = 0.97
2) Climb W2/W1 = 0.985
3) Cruise R = 9,114,000 ft
C = 0.0001389 1/s
V = 0.6M x (994.8 ft/s) = 596.9 ft/s
L/D = 16 X 0.866 = 13.9
W3/W2 = e{-RC/VL/D} = e-0.153 = 0.858
Where would you perform iteration here until your only off by 1% of the desired weight? The aircraft is assumed to weight 10,000 lbs. Thanks.
C = 0.0001389 1/s
RE: Mission Segment Weight Fractions
taking nothing from Dan Ramyer, and assuming your W3/W2 saying that travelling 9E6ft, = 2E3 miles, consumes "only" 15% of the weight of the plane; i'd say that doesn't make sense.
look at the fuel fraction of any large long range transport, fuel makes up something like 40-60% of the AUWt.
good luck with your project.
TTFN
ASW Requirements
The key requirements for this mission for our hypothectical antisubmarine would be: the ability to loiter for 3 hrs at a distance of 1500n miles from the takeoff point. While loitering on-station, this type of aircraft uses sophisticated electronic equipement to detect and track submarines. For the sizing example, this equipment is assumed to weigh 10,000 lb. Also, a four-man crew is required, totalling 800 lbs. The aircraft must cruise at 0.6 Mach number.
L/D Estimation
For initial sizing, a wing aspect ratio of about 10 was selected. With the area of the wing and canard both included, this is equivalent to a combined aspect ratio of about 7. The author then gathered the wetted area ratio (Swet/Sref) from a chart in this chapter from historical trend(actually comparing this design to a Beech Starship)This yielded a wetted aspect ratio of 1.27(i.e., 7/5.5). Finally a maximum lift-to-drag ratio of about 16 was given(again from historical trend).
ASW sizing calculations
Mission Segment Weight Fractions(Britsh Units)
3) Cruise R(Range)= 1500 n.mi=9,114,000ft
C(fuel consumption)=0.0001389 1/s
V(velocity)=0.6Mx(994.8 ft/s)=596.9 ft/s
L/D(lift/drag)=16x0.866 =13.9
W3/W2=e{-RC/VL/D}=e-0.153 = 0.858
4)Loiter E=3 hrs = 10.800 s
C=0.4 1/hr = 0.0001111 1/s
L/D = 16
W4/W3 = e{-EC/L/D} = e-0.075 = 0.9277
5) Cruise(same as 3) W5/W4 = 0.858
6) Loiter E= 1/3 hr = 1200 s
L/D = 16
W6/W5 = e-0.0083 = 0.9917
7)Land W7/W6 = 0.995
Can be found as a worksheet from the following:
http://www.aircraftdesign.com/ASW.xls
Thanks.
2) the problem answers your question ... when your guess (B21) equals the calculated result (B35) you're finished.
3) "they" frown on student posts
and thx for the star !
TTFN
I'm not sure about some of your assumptions, take a look at what the S3 did, or even the Tracker, even allowing for newer materials & smaller electronics, I'm not sure you mass makes sense, depending what mass it is.
http://en.wikipedia.org/wiki/S-3_Viking
KENAT,
Have you reminded yourself of FAQ731-376: Eng-Tips.com Forum Policies recently, or taken a look at posting policies: http://eng-tips.com/market.cfm?
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
