VW environment in CATIA or CATBatImpXMLSet
Hi all, I am new in forum and I need some help. Does anyone experience with installing VW Standard environment in CATIA v.5? Or with CATBatImpXMLSet utility in CATIA?
During using utility I get this message :
Usage :CATBatImpXMLSet.EXE FileName [mode]
FileName :
Path of the XML file to import in the current V5 environment.
mode:
-admin in order to run in administrator mode.
The default mode is the user's mode.
ERROR: Cannot launch child process
How I can change to being CATIA in admin mode in default?
Of course I have CNEXT -admin, and when I start CATIA I am in admin mode, but probaly that is not default.
thank you for any answer.
Jan
FileName :
mode:
Jan
