Component Name vs File Name
ok, not sure what happened to my first post so will post again. I have been tracking down a source of crashes in NX5 related to other software we use. What I have found is we get converted files from a UNIX machine and we end up with filenames and component names not being the same, as far as upper/lower case. Our systems are case sensitive so the following would be different parts:
File Name: MyPart.prt Component Name: MYPART.PRT
I need to know if this situation can be captured in Checkmate or something where we can prevent the users from going further until corrected?
RE: Component Name vs File Name
# File system options. If LOWER is set, filenames will be converted to lower
# case before being used. If UPPER is set, filenames will be converted to upper
# case before being used. If neither is set, filenames will be used as the
# user types them in.
For format for the variable is:
UGII_OPTION=LOWER
or
UGII_OPTION=UPPER
Anyway, try changing that in you ugii_env.dat file or adding this variable to your user/system profile.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
But, that would only prevent users from creating files, not sure what it would do with files that are supplied as lowercase to us from other companies? I can easily test it again tomorrow.
