Leak Detection in Underground Piping
What are the most applicable methods for leak detection in old underground oil pipes in operation.
RE: Leak Detection in Underground Piping
If close to the surface, infrared thermography can help.
Ultrasonic or acoustic emission methods will work.
There are a lot of answers to that.  If the piping is properly configured (not much "old" pipe is) then running a smart pig is the best and fastest way to find leaks and near-leaks.
If you can't run a smart pig, then if you suspect a leak (from a material balance for example) then you have to patrol the pipeline looking for lakes that didn't used to be there or unusual growth patterns in the vegetation (outgassing from a leak will kill some plants and act as a fertilizer for others).
For oil lines, many people have good luck patrolling the lines from the air.  For gas lines, the success is much more limited.
David
