Material Balance
Material Balance
All, I am not even close to being a chemical engineer but I am putting together a demo for an RBI module that requires the input of many variables. One of the variables that has to be entered is the process stream make up for a generic crude unit. The application needs to understand what is in the vessels and piping in order to generate the potential damage mechanisms. What I was needing was material balance sheets for a crude unit that lists the various process fluids in mole %. Any assistance would be greatly appreciated.
RE: Material Balance
Every crude feed has different properties. Different amounts of components different boiling points. You need a crude assay and from that information you can create a crude unit simulation using HYSYS. Then you can get the material balances. You need to ask what the crude assay looks like (usually expressed in Deg API & wt %). You may need to combine different assays also for crude mixtures (HYSYS is good at this and design ii)
Yours,
Mike F.
