speed control on single phase motor
Is there a way to wire a 1/4hp capacitor-start motor so that you get a slow and a fast speed? I am trying to replace a blower motor on a hydronic ceiling unit in a gym and they are wired for slow and fast speeds, yet the nameplate of the existing motor is single speed, 1725 rpm.
RE: speed control on single phase motor
The other option is a two speed motor, but a 2:1 speed ratio is not much good for fans.
The motor may have been changed from the OEM motor already.
But if you take a chance and connect a single speed motor to an existing speed reducing reactor, monitor the current. If the motor runs slower and the current is below the nameplate value you may be safe.
Disclaimer; You are on your own. If you come back complaining that you changed a special purpose motor to an off the shelf generic motor and it failed, I will disavow all knowledge of this conversation, change my handle and disappear.
Bill
"Why not the best?"
Jimmy Carter
There are some motors in air handler service that seem to have 3 or 4 speeds when you run them on different taps.
Keith Cress
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
Keith Cress
