Inserting only a few sheets from a larger set of drawings
Hey guys, real quick question.
I have a set of drawings with about 10 sheets in it. I need to insert two drawings from another set of drawings with around 20 sheets in it. Is there a way to do this without having all the models and drawings from the 20 sheet set become associated with my 10 sheet set?
This is probably a trivial question, but I want to be absolutely sure. Some of the models in both sets have the same names, and that's not a mistake I want to make again.
Thanks fellas.
