Concrete Piers for Underground Propane Tanks
Would anyone know of web sites where data (dimensions, weights, bearing pressure on footing, concrete type, the whole work...)on concrete piers are available.
Tank dia. 84", Min length 12'.
I found one site but with limited info. I just don't want to redesign this limited info. in ACAD to determine weights and calculate adequacy of footing size if I can help it.
RE: Concrete Piers for Underground Propane Tanks
JAE, structural engineer have nothing to do with my request. I can personally design these piers with all the reinforcement needed and with the proper size footings, and have carpenters lay out the forms and concrete poured, however, it is more cost effective if commercially bought.
Then why post a question here? You know how to do it, knock yourself out.
chicopee, I'm not sure what footing system you are looking for (I have no experience in that area) but I find it suprising that you expect to down-load a design which will suitable for a specific tank in a specific location.
I assume that you will still be liable for the design.
I have found one site with drawings but no further details about their weights, reinforcement, anchoring points for straps etc...
I want to control cost on this project.
