PED Joint Coefficient
Can someone explain 7.2 of the 97/23/EC PED dealing with joint coefficients?
RE: PED Joint Coefficient
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
Willem Mast
wmd2
What that statement tells you is that the testing will need to be extended to the entirety of the weld joints to adopt a coefficient of 1. What kind of tests it is not specified here, it is the purpose of the technical rules.
prex
Or do i have to use a welding component also if i buy prefabricated piping components such as welded pipes and tees?
For pressure pipes and piping components, when would you use a lower coefficient than z=1.0? Obviously when the weld is not 100% tested, but when would that be?
