Test the Macro
Test the Macro
Can anyone test this macro. I have tried it on different machine and getting "Out of memory" error. If you are able to run it successfully, kindly let me know.
Link for the macro : htt p://www.es oxrepublic .com/freew are/BlankD atums2.php
TIA
TIA
Deepak Gupta
SW2009 SP3.0
SW2007 SP5.0
RE: Test the Macro
Deepak Gupta
SW2009 SP3.0
SW2007 SP5.0
RE: Test the Macro
Artem Taturevich, CSWP
Software and Design Engineer
AMCBridge LLC
www.amcbridge.com
RE: Test the Macro
Deepak Gupta
SW2009 SP3.0
SW2007 SP5.0
RE: Test the Macro
I use this macro every day, and every version has always worked for me. The one change I made was with how the macro acquired the SW application object, which fixed the problem for the one user who had lodged a coomplaint.
Without the ability to replicate the failure, I can not track down the source of the problem. I will take some time today to look for more potential problems.
Meanwhile, I would welcome any indepenedent exploration of the problem. It is a macro, and the code should be available to examine.
--Tick
http://www.EsoxRepublic.com-SolidWorks API VB programming help
RE: Test the Macro
http://
RE: Test the Macro
If anyone w/ 64-bit can get it to run, I would like to know.
RE: Test the Macro
Thanks for the new macro. I will give it a try on both 32 and 64 bit machines and update you.
Deepak Gupta
SW2009 SP3.0
SW2007 SP5.0
RE: Test the Macro
32 bit: SW07 SP5.0 & SW09 SP3.0
64 bit: SW07 SP5.0
Deepak Gupta
SW2009 SP3.0
SW2007 SP5.0
