Inconel 625 cladding on valves
We have to supply some valves with inconel 625 internal cladding. These items must be supplied according to ISO 15156.
As we need to qualify the welding procedure according to ASME IX and ISO 15156, we need to understand if we have to perform any corrosion test on the specimens. Is this somewhere specified by ASME IX or ISO 15156 ?
In case any corrosion test is required, which standard has to be applied ? (ASTM G48, ASTM A262)
RE: Inconel 625 cladding on valves
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
