Correct Exh Gas Temp on Methanol?
Tuning an injected methanol motor - what EGT should I be looking for? One of the dyno sheets that came with an earlier motor was in the 1100 deg F range - we hit 1400 F peak at the track and I'm concerned about melt down....
Hilborn 2 7/16", 360 cu in, main pill 68. hispeed bypass pill 66 @ 85psi, low speed 70 pill, KSE pump
Thanks for the help
Thanks for the help
Keep the wheels on the ground
Bob
showshine@aol.com
RE: Correct Exh Gas Temp on Methanol?
the amount of Torque ,,,and CID engine size
could you post the actual measured CR and Peak Torque
and the engine size CID figures , then i could calculate
a baseline EGT
the 1100 deg F doesn't sound too far away ??
Larry Meaux (meauxracing@mindspring.com)
Meaux Racing Heads - MaxRace Software
ET_Analyst for DragRacers
http://www.mindspring.com/~meauxracing/
Support Israel - Genesis 12:3
