first steps with API 614, need support!
I'm new here. I' living in Europe. I'm very glad that I find this forum.
I have to design a pressure duplexfilter according to the API 614.
My question are:
 1-which kind of castings materials are allowed to satisfy the API 614 requirements?
2-Can we use iron cast for this filters?
Thanks!
I think I will have more questions within the next weeks and I hope I can find support from you :))
RE: first steps with API 614, need support!
Excerpt from API 614;-
"4.4 Pressure design code
 The pressure design code shall be specified or agreed by the purchaser. Pressure components shall comply with the pressure design code (n.b.- ASME VIII or similar) and the supplementary requirements in this part of ISO 10438".
Hence, the cast iron housing must be in accordance with ASME VIII or a similarly recognised prssure vessel code.
cheers,
gr2vessels
Chapter 2 Special Purpose - 1.1.17 Pumps, filters, strainers, coolers, traps, valves, and all other components that retain oil under pressure and are external to the reservoir shall be made of steel.
Chapter 3 General Purpose - 1.2.14 When specified, pumps, filters, strainers, coolers, traps, valves, and all other components that retain oil under pressure and are external to the reservoir shall be made of steel.
For this spec it is tough to just state API614.  That is to general.  You need to specify if you are designing to Chapter 2 or Chapter 3.  Chapter 2 is much more stringent than Chapter 3.  As you can see above, Chapter 2 does not allow Cast Iron, whereas Chapter 3 does.
Nick Yackanech
www.trola.com
Are you designing a filter or looking for a filter ?
If looking, Call indufil.   They are in Europe and make most of the filters I see on API 614 systems.
Thank you for your support!
I have the " Lubrication, shaft-sealing and oil-control systems and auxiliaries" directive (ISO 10438:2007), Fifth edition, April 2008.
I don't found the instructions 1.1.17 and 1.2.14!
I think I don't have the right directive!:)
