Stainless steel choice
what is the best grade of stainless steel (bars and plate) which can be easily welded, is cheap and readily available and provides reasonable hardness - 303, 304 or 316 or something else?
RE: Stainless steel choice
Weldability, price, availability and hardness are all relative.  What are you doing with it?
it will be a survey monument, located in a spillway, subject to erosion from flowing water, rocks, sand etc. will need to weld a plate to the top and embed in a concrete structure.
Either 304L or 316L will work for this application.  Both are weldable and corrosion resistant.
