Selecting vessel material for Hydrogen gas Service
Hey Everyone:
I am looking at purchasing some pressure vessels to be used in 6,000 psi hydrogen service operating at a maximum of 120 degrees F.  The three vessel materials under consideration are 1) SA-372, Grade J, Class 70, 2) SA-508-4N, class 1, and 3) SA-543, grade B, class 1.
I was hoping to get some recommendations on which of these materials would be better suited for hydrogen service.  I have reviewd API 941, but it seems to be more applciable to high temperature services.  Any thoughts?  Any other good references about material seletion/suggestions would be awesome!!  Thanks everyone!
RE: Selecting vessel material for Hydrogen gas Service
METTAL CORP   TUF-37
SA-516-70 normalized HIC QUALITY VACUUMN DEGASSED CALCIUM/SUFIDE CONTROL  ULTRASONIC TESTED
if the vessel is not to large of diameter and gets too thick
we've gotten 4 1/2" - 6"in this material and it is great!
CE should be less than .40 for hydrodgen
I realize that you are looking at forged materials in the 20-30" range.  I guess you know that is european or japanese built vessels
