Cyclone in Batch Operation?
I need to separate peel particles form a high flow gas system. It is a known fact that at steady state cyclones are very effective for such separations, but unfortunately in my case the gas discharge occurs for 3 seconds every minute. That is to say there is no flow into the Cyclone for 57 seconds during the cycle which is then followed by a 3 second "flow burst" and the cycle repeats again. Can cyclones handle this sort of separation or will the vortex collapse during the 57 seconds of no flow and therefore during the flow burst no effective separation is obtained as the vortex cannot be instantly re-formed?
BizeB
BizeB
RE: Cyclone in Batch Operation?
I'm interested with cyclone to separate liqd & solid up to efficiency of 99.9% for less than 10 micron. Is that possible to achieve using cyclone? also could anyone pls suggest where i can get the literature / manufacturer that design a combination of cyclone + coalescor in one single vessel.
Thank you
Aiman
