gearbox inputs
gearbox inputs
Are there commercially available reduction gearbox units that have 2 inputs shafts. One input shaft for a high speed motor and one for a low speed motor.
RE: gearbox inputs
RE: gearbox inputs
RE: gearbox inputs
dvd is assuming your are referencing electric motors. If you are refering to hydraulic motors, you will still have a drag problem (very small) from the idle motor, but you can get hydraulic pump drives from a number of sources (Durst div. of Regal-Beloit, FUNK, EATON...etc.) that will work equally well in reverse (i.e. a hydraulic motor to drive the shaft.
Hope this helps,
FINN
