cone to flat pattern in SW
I have made a cone in sw using revolve. It's a thin because I used only one line in a angle. I would like to control the thickness and flatten the cone. Can some on tell me the best steps for making a cone that needs to be converted to a flat pattern? I made the code 359.999 deg so not to close it and then tried to insert/sheetmetal/bends after that it just tells me no bends found.
RE: cone to flat pattern in SW
Jeff Mirisola, CSWP, Certified DriveWorks AE
CAD Administrator, Ultimate Survival Technologies
My Blog
If you click on the Grey button just under the title at the top of your post (NOT the Green Search Button higher up) and type flatten cone into the keyword box you'll get quite a few tips and methods.
Trevor Clarke. (R & D) Scientific Instruments.Somerset. UK
SW2009x64 SP4.0 Intel Core i7 2.94Ghz, 12Gb Ram, NVIDIA Quadro FX3700 Driver: 6.14.11.8246
SW2009x64 SP4.0 Intel Core 2 Duo 3.17Ghz, 8Gb Ram NVIDIA Quadro FX3700 Driver: 6.14.11.8246
Should have been Gray Search Button!
You can also try making the cone and then converting to sheet metal after creating the revolve using "Insert-->Sheet Metal--> Bends".
http://www.EsoxRepublic.com-SolidWorks API VB programming help
http://w
thread559-199521: Problem Converting Cone To Sheet Metal Part
Chris
SolidWorks 09, CATIA V5
ctopher's home
SolidWorks Legion
http://w
