Quality of 2D display in NX5
Hi
I'm working in NX 5.0.4.1 and I am finding that the display quality of the curves in the 2D drafting is pretty poor, with the circles all jagged.
Any way to improve this?
Also, is there any significance of the background colour of the sheet - seems to vary randomly between light grey or white.
Any advice appreciated.
RE: Quality of 2D display in NX5
Your display tolerance in either the customer defaults or an environment variable will address the jaggedness.  This may cost you a bit on the performance side, however.  It all depends on the tolerance you use.
This is common in CAD and when zooming in tight, you will notice this more often than usual.  Sometimes regenerating or refreshing the display will force a redraw, which will then smooth the display out.  If you're not experiencing the jagged edges at "normal" zoom levels and only when zooming in very close, then I wouldn't mess with it because you'll have longer redraw times when zoomed further out and that isn't really necessary in most cases.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
It is necessary to eliminate things one at a time starting with the most likely which is indeed probably as Tim suggested. Also make sure that you don't have the base view set to "Faceted representation", or only reps loaded in your assemblies.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
Thanks for your responses, turns out that the following option sorted out the problem:
Preferences>Visualisation preferences>line tab> curve tolerance.
Set Line font display to 'software'
Then modified tolerance from 0.005 down to 0.0001. Job done. No loss of speed or display issues at thet value. Nice smooth curves now.
Changes only seem to apply on a single drawing. Is it possible to make the changes so that every subsequent new drawing is set? I know that NX5 preference settings are a pain to get set up right.
Rgds Rob.
Rob,
The Curve Tolerance will be in either the Customer Defaults or ugii_env.dat.  I'm thinking it's Customer Defaults.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
