Fluidized bed coating process
I am researching methods for coating oddly shaped agricultural seeds with a hard spherical coating. A simple building up of layers of films will not make a long thin seed round, except perhaps with an excessively thick shell. Other methods involve isolating individual seeds and delivering them into the center of a drop, which falls into a curing vessel.
One of several possibilities is a fluidized bed method where the seeds are suspended in a jet of air and atomized coating material. I believe if the viscosity of the material before curing is low enough, the surface tension high enough and the collisions between particles kept minimum, that the suspended seeds would develop spherical drop like coatings.
I have found example of this making small spheres (microns to millimeters), but nothing up to several centimeters as large seeds would require.
If anyone has any experience or knows of references relating to this process, especially with water permeable, near ambient temperature setting coatings, please share.
thanks.
thanks.
RE: Fluidized bed coating process
Phillip
pforsythe@forsytheandlong.com
