Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...It is good to know that there are groups such as this willing to share knowledge in this money driven economy..."
Geography
Elastic rubber with excellent mechanical cycling properties
alexVI (Chemical)
13 Jul 09 12:57
I'm looking for a material with high elasticity (>600% elongation) that can whistand mechanical cycling (at least 100,000 cycles.) It will be used as a thin wall (1/64" - 1/32")  tube  with 3/8" ID.   The air pressure in the tube  changes  within 1-5 psi range. The tube has to be able to  expend and contract in diametre by at least 500%.
GrahamBennett (Materials)
14 Jul 09 4:22
For very high elasticity you will need a 100% NR based compound - probably unfilled and unplasticised but with about 2phr 6PPD. Whether or not this would give you a life of >100k cycles remains to be seen.
alexVI (Chemical)
15 Jul 09 13:18
Are there any commercially available material with elasticity of 300-400% that has long cycling life?
16 Jul 09 4:28
I don't know. I suggest you talk to a local custom compounder.
Close Box
Join Eng-Tips® Today!
Join Us             Close
