PAD EYE CALCS
PAD EYE CALCS
PAD EYE CALCS
hi guys,
Could any of you help me with calcs for FOS for pad eye. how do you calculate the area of tension to get FOS.
Thanks in advance
RE: PAD EYE CALCS
I'm drawing a blank here - FOS?
RE: PAD EYE CALCS
Falling Object Safety?   8<)
RE: PAD EYE CALCS
The 13th Edition AISC steel deign manual has a small section in the commentary addressing pad eye design (structural steel only).  OSHA also specifies the minimum factor of safety for certain conditions with connections carrying people, etc...
Hope this helps.
RE: PAD EYE CALCS
webhelp82, ASME BTH-1 addreses design of lifting equipment and will doubtless answer your question.
Available from ASME, fairly modest cost.
Mike
