how to consider tolerance in process design
How instruments tolerance affect system process? If I have a range of 45 to 55 and want to measure up to 0.1. What instrument do I need (tolerance???)?
RE: how to consider tolerance in process design
cheers,
gr2vessels
This pressure example cannot be extended to temperature rangeability.
To be sure, you can consult instrument engineer or ask your supplier.
You can download instrument specification from website to check their measurement accuracy as well. Try E&H.
htt
I hope this is what you are looking for.
