Underground Stainless Steel Water Pipeline and Tank Rehab
I am refurbishing a 50 year old, partially buried, wire wound concrete potable water tank in the DFW, TX area. I would like to replace all the existing cast iron tank piping and undergroung piping with welded 304 Sch. 10 stainless steel piping. Please let me know if you have had success with underground SS water piping or not, especially with tank refurbishments. Tank nozzles have cast iron sleeves and must remain. Any concerns with galvanic corrosion? Any suggestions on tank refurbishment based on experience will be appreciated too, especially successful (or non-successful) AWWA approved tank coatings. Your help will be appreciated.
RE: Underground Stainless Steel Water Pipeline and Tank Rehab
I'd also think you will need to pay close attnetion to your soil characteristics to ensure you do not get a chloride stress cracking problem, especially at the butt welds.
Thanks!
Pete
I am going to research this further. I am especially concerned about galvanic corrosion (CI sleeves vs. SS pipe) and chloride stress cracking corrosion. SS should meet AWWA code--it is used for food and beverage piping--but I need to verify this.
The cast iron will be corroded more rapidly because of the galvanic couple and the rust from it could harm the stainless. Use 304L if welds can't be quickly cooled.
I discount the risk of SCC in this environment,ie ambient temperatures and low risk of pitting to initiate the SCC.
Why don't you get some field experience from one of the large pipe producers from whom you might buy the pipe to supplement what you get from eng-tips?
Sorry to sound so critical, but there is no need to reinvent the wheel on water engineering, believe me!!!
PS: I would not place welded joint pipe into tank influent/effluent pipe applications.
Please explain further why you would not use welded joint pipe for the tank influent/effluent.
