Solidworks - Turn Object Into Light Source
I've been working on a model of a small building in solidworks. I want to put lights inside the building that look like normal fluorescent lamps.
I've tried playing with the material properties and putting spot lights inside a pre-made part but nothing I've done looks very good.
Is there a way I can make a part that emits light which I can put inside the building assembly?
RE: Solidworks - Turn Object Into Light Source
You can also add point lights in the "Lights and Cameras" folder. Perhaps add a point light inside a translucent part?
Also don't forget to turn down the ambient and external directional light.
Dan
www.eltronresearch.com
Dan's Blog
Jeff Mowry
www.industrialdesignhaus.com
A people governed by fear cannot value freedom.
