Waterhammer analisys its obligatory ?
There exists any code asme? api?, i know that it depends of the situation, but i would like to know when its extremely necessary, if its critic?
Best regards for all,
Cesar.
Cesar.
RE: Waterhammer analisys its obligatory ?
E) Sources of pressure to he considered include ambient influences, pressure oscillations and surges, improper operation, decomposition of unstable fluids, static head, and failure of control devices.
In my mind it means that if the waterhammer analysis limits/defines the design envelope then it is obligatory.
Its not _always_ that simple
Best regards
Morten
GIGO pays the bills.
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
Pipeline Studio
Olga2000
Stoner Pipeline Simulator
Hammer Bentley
AFT Impulse
Tnhx all.
Estimate water hammer loads in steam piping
The Problem is more complicated because of the two-pahses flow.
http
Before a project of a line of pumping to be constructing, how to determine if it is necessary or not to study the transitory phenomena (known normally with the name of "water hammer"?
The first thing that must be done is to calculate the pressure in regime that supports the pipeline.
Then Jucowski's pulse must evaluate of overpressures, that is the maximum value that the same one can adopt. Later, the pressure is evaluated in regime(diet) + - the pulse and is observed if it comes to dangerous values for the break of the pipeline (to see specifications of the same one) or minor values to-6 to-7 m of water column to avoid cavitation in the whole pipeline. Of being near these limits in some case it suits to study with more detail the system
