Adding weitgh to a table (drafting) in UG 5
I need to add the weight of a part to a unigraphics NX5 dwg table. I can extract expressions and attributes, but I can't find a way to link the weight field from the properties.Got it to work in NX2 but not 5.
RE: Adding weitgh to a table (drafting) in UG 5
Tools -> Expressions...
...and and then go to the bottom of the dialog and select the Measurement option and select Measure Bodies and select the model and hit OK (you will probably want to edit the name of 'weight' measurement to something like 'Weight' so that it will be easier to find later on.
Now open your drawing and if you already have your Tabular Note created, just select the desired 'cell', press MB3 and select 'Style' and under the 'Cells' tab you can decide what sort of format that you wish (for numerical data you can use either Text or Number, the difference being where and how you control the number of decimal places) and if you wish any prefixes or suffixes be added to the value in the cell. Now hit OK and once more select the 'cell' and press MB3 and this time select 'Edit Text' and then select the 'Relationships' tab and then select the 'Expression' option. Now if you working with a Master Model drawing, you will need to select the 'Link to Part' button and select the component to get the list of available Expressions. Anyway, select the desired expression, which I had suggest that you name 'Weight' (if you had selected the 'Text' type for the cell, then you will need to set the 'Format' in this dialog to control the number of decimal places, but if you selected the 'Number' option than you will control the decimal places back in the Cell 'Style' dialog) and hit OK. Now you can also add any additional text here in the Annotation editor if you wish or just hot OK once more and you're done.
Anyway, that should do you.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
John R. Baker, P.E.
Industry Sector
Cypress, CA
Why not use a parts list and have the component masses show there? It may be what you want or maybe not. I wish that NX would also provide masses in the part list for assemblies.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
As far as the updating, if you link directly to the Measurement Expressions, you shouldn't have any problems. Now if you've passed those values to an Attribute and then reference the Attribute, there could be some delay getting the last link in the 'chain' to update in a timely fashion (it will update upon saving and reopening the part, but might not update if something is changed during your current session). These update issues will be fully cleared up when we implement the new Attribute architecture in a future release of NX.
John R. Baker, P.E.
Industry Sector
Cypress, CA
I'm sorry, but that is all that I'm allowed to say at the moment. When we get to the point where we have a better idea of both the content and the schedule of that release, we will be more forthcoming, but until then...
John R. Baker, P.E.
Industry Sector
Cypress, CA
