Who is the current Siemens Guru for VisMockup?
Simple question, anyone have an answer?
RE: Who is the current Siemens Guru for VisMockup?
Not I said the wolf!
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
<sigh> Thanks Hudson - just trying to make a ripple or two in a rather quiet pond, to see baubs up to the surface.  In all seriousness, while it is nice to see a guy like John Baker on the UG side of the house, it is not so nice to not see if there is a TCVis counterpart.
I doubt that a TC Vis guru would even subscribe to this forum...
I think that Siemens or your local support would be your best bet - however I suspect that this wouldn't come for free!
You will be surprised NXConsultants at lack of depth with TCVis, even within the confines of the PLM folks.
I feel your pain! I used to be a Siemens guy, I found Vis help a little hard to come by on occasions and that's when I worked for them!
It might be an idea to take this up with your Siemens sales guy or the manager of your local helpdesk and ask if there is another place that you can post questions
Do you use the BBS notes forum on the support website? There isn't a Vis section, but it's another avenue.
Are you in England? If so I could get you the name of the guy who just cam and taught us Vis Mockup.
Best regards
Simon (NX4.0.4.2 MP10 - TCEng 9.1.3.6.c)
www.jcb.com
Life shouldn't be measured by the number of breaths you take, but by the number of times when it's taken away...
Sorry JCB - I am on the other side of the pond.
NXConsultants - actually, I did take the BBS route on the Siemens sight first, as well as nag what contacts I have with Siemens, before I appealled to the audience here.
MSawtell, the best contact for VisMockup is their internal support number. Unfortunately, most of the development and support comes from a small group of people so I'm not sure how much help they will be able to provide. But on the other hand, you should be abel to get through. It has worked for several of us in the past: 814-237-5000.
FEA88 - thanks for the tip, going to try them tomorrow when my language skills will be a little more coherent. morning
