change coordinate
change coordinate
Hi,im desperat because i have to draw the stress true the thickness and for that im trying to find out how to do it.
I'm applying an interior pressure (13332 Pa) and an external pressure (3999 PA) and normaly i should found the internal pressure at the beginning of the thickness and the exterior pressure at the end of the thickness wish in normal,but i dont know how to set the coordinate système?
If anyone can help me out,it will be thankfull.
I will attach the CAE file in case of you wanna see.
thanks alots
thanks alots
