instance feature vs circular array
I looked at instance feature since NX5. I followed an example John shown (I liked). A flanch with instanced sketch and the new hole. Now I want to do component field with those holes and a bolt. Doesn't work or what I have done wrong? Iset only works with the instance hole?
thx in ad
thx in ad
RE: instance feature vs circular array
Instance geometry creates the same end result (holes in a flange) but the component array does not recognise it as an instanced feature.
So in this case use a simple hole, create an array feature, then use ISET OR use Instance Geometry and accept the limitations of a manual component array.
I've only tested this in 5, Perhaps John B will have a little more detail on the limitations of this, it's a couple of years since I worked for Siemens..
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
