SET n command
SET n command
Hello everybody,
I'm trying to divide a machine in components by the SET command, but I'm having some problems with where I have to write it.
I tried to do it in the Case Control Section and Executive Control Section text boxes, but it didn't work.
I will appreciate any kind of help.
Thank you.
Thank you.
RE: SET n command
However I have been caught out in the past by forgetting the maximum line length in this section is 72 charachters.
RE: SET n command
gwolf
