Australian Steel Section Tables Circa 1900
As part of floor loading assessment for an historic building, I have noted one of the main structural I-beams to be 380mm deep approx by 150mm. Unfortunately, this doesn't correlate with anything in the current steel section tables.
Would anyone have steel structural sections table for the period 1870-1910? I suppose iron may have been the construction material as well then (hopefully not though) so any section tables for that era would be appreciated.
Many Thanks
Many Thanks
RE: Australian Steel Section Tables Circa 1900
When in doubt, just take the next small step.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
This seems to be a free search engine for section properties:
http://www.aisc.org/content.aspx?id=2868
Else design guide 15 can be purchased here:
http
h
It should list everything that came from the UK for that period.
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
