Chilled Water Pump : Flow Rate
I'm quite new in this field. I have a question to ask someone who can explain or suggest me about my problem below;
I have 4 Chillers & 4 Chilled Water Pumps at my plant, they are designed at the same flow rate 2000 LPM ( 1 CHP/ 1 Chiller). the suction & discharge pipe size for each unit is 6" and connect to 10" header.
Nornally, I run 2 or 3 units per day (depend on load), there are no problem. However, if I try to only 1 set ( 1 CHP & 1 Chiller ), the CHP will roar. If I run the 2nd set, the roar will disappear.
is possible that sound are occurred by the flow rate from 1 set is not match to the 10" header?
Thank you in advance for your help.
RE: Chilled Water Pump : Flow Rate
I've tried as your suggest and there are no more roar anymore.
Thanks again.
